Saltar al contenido principal
Samsung Gravity TXT microSD Card Replacement
Qué necesitas
  1. Samsung Gravity TXT microSD Card  Replacement, Battery: paso 1, imagen 1 de 2 Samsung Gravity TXT microSD Card  Replacement, Battery: paso 1, imagen 2 de 2
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
  2. Samsung Gravity TXT microSD Card  Replacement: paso 2, imagen 1 de 1
    • Lift the back cover away from the main body of the phone.
  3. Samsung Gravity TXT microSD Card  Replacement: paso 3, imagen 1 de 1
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
  4. Samsung Gravity TXT microSD Card  Replacement, microSD Card: paso 4, imagen 1 de 3 Samsung Gravity TXT microSD Card  Replacement, microSD Card: paso 4, imagen 2 de 3 Samsung Gravity TXT microSD Card  Replacement, microSD Card: paso 4, imagen 3 de 3
    • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
    • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
    • After the click, release the microSD card to allow it to pop out.
    • Remove the microSD card from its slot
    • When placing the microSD card back in the phone, make sure the card clicks in place.
Conclusión
Mounir Karmada
Miembro Desde 07/07/15
465 Reputación
4 Guías creadas
Equipo
IUPUI, Team 1-1, Renguette SU 2015 Miembro de IUPUI, Team 1-1, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G1
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 227
