Saltar al contenido principal
Samsung Gravity TXT SIM Card Replacement
Qué necesitas
  1. Samsung Gravity TXT SIM Card Replacement, Battery: paso 1, imagen 1 de 2 Samsung Gravity TXT SIM Card Replacement, Battery: paso 1, imagen 2 de 2
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
  2. Samsung Gravity TXT SIM Card Replacement: paso 2, imagen 1 de 1
    • Lift the back cover away from the main body of the phone.
  3. Samsung Gravity TXT SIM Card Replacement: paso 3, imagen 1 de 1
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
  4. Samsung Gravity TXT SIM Card Replacement, SIM Card: paso 4, imagen 1 de 3 Samsung Gravity TXT SIM Card Replacement, SIM Card: paso 4, imagen 2 de 3 Samsung Gravity TXT SIM Card Replacement, SIM Card: paso 4, imagen 3 de 3
    • Using your finger, push the SIM Card down and slide out of the slot.
    • Slide the SIM card out enough to grab it firmly.
    • Remove the SIM card away from the phone.
    • Follow the visual on the bottom of the SIM card slot to put the SIM card back in the correct orientation.
    • When sliding the SIM Card back in the slot, make sure the card goes all the way in the slot until it hits the stopper.
Conclusión
Mounir Karmada
Miembro Desde 07/07/15
465 Reputación
4 Guías creadas
Equipo
IUPUI, Team 1-1, Renguette SU 2015 Miembro de IUPUI, Team 1-1, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G1
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 861
