Saltar al contenido principal
Samsung Gravity SGH-T669 Front Glass Assembly Replacement
Qué necesitas
  1. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Battery: paso 1, imagen 1 de 3 Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Battery: paso 1, imagen 2 de 3 Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure your phone is powered off.
    • Use a plastic opening tool to remove the rear battery cover.
  2. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 2, imagen 1 de 2 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 2, imagen 2 de 2
    • Remove the battery by pulling up from the bottom right corner.
    • Remove the SIM card and the Micro SD card.
    • SIM card
    • Micro SD card
  3. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Casing: paso 3, imagen 1 de 1
    • Remove the six 2.8 mm Phillips screws.
  4. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 4, imagen 1 de 3 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 4, imagen 2 de 3 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 4, imagen 3 de 3
    • Use a plastic opening tool to pry off the casing.
    • The volume button, camera button, and lock button may fall out as you remove the casing. If they are still on the phone, remove them.
    • Lock button
    • Camera button
    • Volume button
  5. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Motherboard: paso 5, imagen 1 de 2 Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Motherboard: paso 5, imagen 2 de 2
    • Disconnect the LCD cable with a plastic opening tool.
    • Remove the two 2.8 mm Phillips screws that hold the motherboard in place.
  6. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 6, imagen 1 de 1
    • Remove motherboard.
  7. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Separating the halves: paso 7, imagen 1 de 2 Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Separating the halves: paso 7, imagen 2 de 2
    • Remove the six 1.5 mm Phillips screws.
    • Very gently peel the LCD cord off the slider assembly.
  8. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 8, imagen 1 de 1
    • Remove the keyboard housing from the screen housing.
  9. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Screen casing: paso 9, imagen 1 de 1
    • Remove the four 2.5 mm Phillips screws.
  10. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 10, imagen 1 de 3 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 10, imagen 2 de 3 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 10, imagen 3 de 3
    • I found that my plastic opening tool wasn't strong enough (it broke) to pry open this casing.
    • I used a 1.3 mm Flathead screwdriver as an opening tool.
    • After you have gotten under the edge of the back plate, slide your tool along the length of the plate.
    • Be careful if using a screwdriver to open the casing. While there are a minimal amount of components that can be damaged, caution should be exercised. It is not recommended.
  11. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 11, imagen 1 de 2 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 11, imagen 2 de 2
    • Remove the cover.
    • There are four clips on the underside of the cover, shown in the green and yellow boxes.
    • I found these clips to be the hardest to remove.
    • After removing the yellow clips, these should follow easily.
  12. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Remove the LCD: paso 12, imagen 1 de 2 Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Remove the LCD: paso 12, imagen 2 de 2
    • It's time to take the LCD out.
    • Begin by removing the blue piece of tape.
  13. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 13, imagen 1 de 2 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 13, imagen 2 de 2
    • Disconnect the two ZIF connections using a plastic opening tool.
    • ZIF #1
    • ZIF #2
  14. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 14, imagen 1 de 1
    • Use a plastic opening tool on the bottom of the LCD to pry it off.
  15. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: paso 15, imagen 1 de 1
    • Remove the LCD panel.
Conclusión
2 personas más completaron esta guía.
Andrew Schneider
Miembro Desde 05/31/14
970 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 1,312
