Saltar al contenido principal
Samsung Glyde Camera Replacement
Qué necesitas
  1. Samsung Glyde Camera Replacement, Battery: paso 1, imagen 1 de 1
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Samsung Glyde Camera Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. Samsung Glyde Camera Replacement, Motherboard: paso 3, imagen 1 de 2 Samsung Glyde Camera Replacement, Motherboard: paso 3, imagen 2 de 2
    • Using a Phillips#00 screw driver, remove the six 4mm screws holding the back case together.
  4. Samsung Glyde Camera Replacement: paso 4, imagen 1 de 2 Samsung Glyde Camera Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
  5. Samsung Glyde Camera Replacement: paso 5, imagen 1 de 2 Samsung Glyde Camera Replacement: paso 5, imagen 2 de 2
    • The green film above the camera is the camera connector to the motherboard.
    • Use a plastic opening tool to disconnect the camera connector.
  6. Samsung Glyde Camera Replacement: paso 6, imagen 1 de 2 Samsung Glyde Camera Replacement: paso 6, imagen 2 de 2
    • The golden film connector connects the keyboard to the motherboard.
    • Use a plastic opening tool to disconnect the keyboard connector.
  7. Samsung Glyde Camera Replacement: paso 7, imagen 1 de 2 Samsung Glyde Camera Replacement: paso 7, imagen 2 de 2
    • The circular connector holds the motherboard in place.
    • Using a plastic opening tool, disconnect the circular connector.
  8. Samsung Glyde Camera Replacement: paso 8, imagen 1 de 3 Samsung Glyde Camera Replacement: paso 8, imagen 2 de 3 Samsung Glyde Camera Replacement: paso 8, imagen 3 de 3
    • There is a LCD connector underneath the motherboard.
    • Gently lift the far edge of the motherboard upwards toward the center of the phone.
    • Using a plastic opening tool, disconnect the LCD connector.
  9. Samsung Glyde Camera Replacement: paso 9, imagen 1 de 2 Samsung Glyde Camera Replacement: paso 9, imagen 2 de 2
    • After disconnecting the four connectors, gently lift the motherboard up with your fingers.
    • Place the motherboard in a secure area.
  10. Samsung Glyde Camera Replacement, Camera: paso 10, imagen 1 de 2 Samsung Glyde Camera Replacement, Camera: paso 10, imagen 2 de 2
    • Use your thumb and index finger to grip the camera connector.
    • Pull the camera connector upwards to detach the camera.
    • The camera was glued on, so this may require moderate strength.
Conclusión
Cameron Law
Miembro Desde 10/12/11
142 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-12, Regan Fall 2011 Miembro de Cal Poly, Team 3-12, Regan Fall 2011
CPSU-REGAN-F11S3G12
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 890
