Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide will provide a step by step procedure for installing the internal antenna.
Partes
No se especificaron partes.
  1. Using your thumb, press down and slide the back cover away from the  camera.
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. SALTEA LA ACTUALIZACIÓN
    Ahorra reparando con un kit todo en uno.
    Compra Kits de Reparación
  4. Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together. Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together.
    • Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together.
  5. Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap. Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap.
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
  6. The antenna is located on the bottom of the phone. It is the small rectangular shaped object sticking out on one of the ends. Use a plastic opening tool to prop the antenna out. To do so, slip the tip of the tool on one of the edges of the antenna. Use moderate pressure to pry the antenna out.
    • The antenna is located on the bottom of the phone. It is the small rectangular shaped object sticking out on one of the ends.
    • Use a plastic opening tool to prop the antenna out. To do so, slip the tip of the tool on one of the edges of the antenna. Use moderate pressure to pry the antenna out.
  7. Using a plastic opening tool, disconnect the connector leading from the antenna to the phone. Using a plastic opening tool, disconnect the connector leading from the antenna to the phone.
    • Using a plastic opening tool, disconnect the connector leading from the antenna to the phone.
Conclusión
Cameron Law
Miembro Desde 12/10/11
142 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-12, Regan Fall 2011 Miembro de Cal Poly, Team 3-12, Regan Fall 2011
CPSU-REGAN-F11S3G12
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 986
