Saltar al contenido principal
Samsung Gear VR with Controller Motherboard Replacement
Qué necesitas
  1. Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: paso 1, imagen 1 de 3 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: paso 1, imagen 2 de 3 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: paso 1, imagen 3 de 3
    • Turn the controller upside down to access the battery compartment.
    • The battery compartment is located on the opposite side of the buttons.
    • Press on the top of the battery plate and slide down to remove the cover.
  2. Samsung Gear VR with Controller Motherboard Replacement: paso 2, imagen 1 de 3 Samsung Gear VR with Controller Motherboard Replacement: paso 2, imagen 2 de 3 Samsung Gear VR with Controller Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove the AAA batteries using your fingers.
  3. Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: paso 3, imagen 1 de 2 Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: paso 3, imagen 2 de 2
    • Remove the four 5mm Phillips #000 screws.
  4. Samsung Gear VR with Controller Motherboard Replacement: paso 4, imagen 1 de 1
    • Use the metal spudger to pry the back side of the controller apart from the front.
    • You will have to use the spudger in many different spots along the divide before trying to separate the pieces.
  5. Samsung Gear VR with Controller Motherboard Replacement: paso 5, imagen 1 de 2 Samsung Gear VR with Controller Motherboard Replacement: paso 5, imagen 2 de 2
    • Pull apart the two halves of the controller to access the motherboard.
  6. Samsung Gear VR with Controller Motherboard Replacement: paso 6, imagen 1 de 3 Samsung Gear VR with Controller Motherboard Replacement: paso 6, imagen 2 de 3 Samsung Gear VR with Controller Motherboard Replacement: paso 6, imagen 3 de 3
    • Pry on the two pop connectors with the plastic opening tool to detach the motherboard.
    • Separate the motherboard and trackpad from the rear part of the controller.
Conclusión
2 personas más completaron esta guía.
Jake Criscione
Miembro Desde 01/24/19
587 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S18-G3, White Winter 2019 Miembro de Cal Poly, Team S18-G3, White Winter 2019
CPSU-WHITE-W19S18G3
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 950
