Saltar al contenido principal
Samsung Gear VR USB Connector Replacement
  1. Samsung Gear VR USB Connector Replacement, USB Connector Replacement: paso 1, imagen 1 de 1
    • Remove front cover from headset.
  2. Samsung Gear VR USB Connector Replacement: paso 2, imagen 1 de 1
    • Slide the latch to the right to unlock the current connector.
  3. Samsung Gear VR USB Connector Replacement: paso 3, imagen 1 de 2 Samsung Gear VR USB Connector Replacement: paso 3, imagen 2 de 2
    • Lift connector clip away from headset and towards you.
    • Slide current connector out and away from headset until it is disconnected from connector clip.
  4. Samsung Gear VR USB Connector Replacement: paso 4, imagen 1 de 1
    • Select which connector fits the port of the device you wish to use with the Samsung Gear VR.
    • The Samsung Gear VR is packaged with connectors for Micro USB and USB-C.
  5. Samsung Gear VR USB Connector Replacement: paso 5, imagen 1 de 2 Samsung Gear VR USB Connector Replacement: paso 5, imagen 2 de 2
    • Slide the connector that connects to your device back onto the connector clip until you feel it settle into place.
    • Slide the lock latch to the left to secure the connector into place.
Conclusión
3 personas más completaron esta guía.
Equipo
USF Tampa, Team S4-G6, Eyestone Fall 2017 Miembro de USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Miembros
7 Guías creadas
5 comentarios
Hola, quisiera saber donde se consigue esa parte, ni siquiera en samsung lo he logrado
Jose Davinci - Contestar
Were do I get the USB c adapter
helenpaul77 - Contestar
If you want USB c adapter I can give you…but we have to make exchange because I need micro usb adapter not type c
Molefi Aaron -
I have the micro USB adapter and need type c. Please advise as to how this barter may be executed?
Saleem A. Sheikh -
Where can I get micro USB converter for gear vr not type c
Molefi Aaron - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 58
Todo El Tiempo: 16,372
