Saltar al contenido principal
Samsung Gear Fit Screen Replacement
Qué necesitas
  1. Samsung Gear Fit Screen Replacement, Watch Band: paso 1, imagen 1 de 2 Samsung Gear Fit Screen Replacement, Watch Band: paso 1, imagen 2 de 2
    • Place your thumbs on the ends of the screen.
    • Push the watch outward while pulling the band away from the watch.
  2. Samsung Gear Fit Screen Replacement, Screen: paso 2, imagen 1 de 1
    • Heating the device with a hair dryer may warp the screen or damage the device. It it preferable to use an iOpener for this step.
    • For step-by-step instructions on using an iOpener, see the Instrucciones de iOpener.
    • Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
  3. Samsung Gear Fit Screen Replacement: paso 3, imagen 1 de 3 Samsung Gear Fit Screen Replacement: paso 3, imagen 2 de 3 Samsung Gear Fit Screen Replacement: paso 3, imagen 3 de 3
    • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
    • Gently pry the screen loose using a plastic opening tool.
    • If the screen doesn't easily come loose, more heating may be required
  4. Samsung Gear Fit Screen Replacement: paso 4, imagen 1 de 3 Samsung Gear Fit Screen Replacement: paso 4, imagen 2 de 3 Samsung Gear Fit Screen Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers as a lever, pry the inner assembly out of the external casing.
    • This will be harder than removing the screen. Moderate force may be required.
  5. Samsung Gear Fit Screen Replacement: paso 5, imagen 1 de 3 Samsung Gear Fit Screen Replacement: paso 5, imagen 2 de 3 Samsung Gear Fit Screen Replacement: paso 5, imagen 3 de 3
    • Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
  6. Samsung Gear Fit Screen Replacement: paso 6, imagen 1 de 2 Samsung Gear Fit Screen Replacement: paso 6, imagen 2 de 2
    • Gently peel the screen assembly up and away from the device using tweezers.
Conclusión
17 personas más completaron esta guía.
Nathan Powell
Miembro Desde 04/24/14
1,577 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 11-49, Amido Spring 2014 Miembro de Cal Poly, Team 11-49, Amido Spring 2014
CPSU-AMIDO-S14S11G49
4 Miembros
4 Guías creadas
28 comentarios
Hi!
Thank you very much for this tuto. But wher can we acquire the screen ???
Thanks a lot.
AB
aaa - Contestar
Where can you buy replacement screen?
Yele Olaniyi - Contestar
I'm also finding it difficult to buy a replacement screen too. Has anyone discovered some. I thought this website was selling some not too long ago. Any more coming in?
Rochelle - Contestar
Hi guys,
is it possible to detach the display unit from the protective plastic cover (I think it's not glass) ?
alexxtodorov - Contestar
Does anyone know where to get the replacement screen?
MrGratts - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 40
Todo El Tiempo: 53,530
