Saltar al contenido principal
Samsung Gear 360 Speaker Replacement
Qué necesitas
  1. Samsung Gear 360 Speaker Replacement, Case: paso 1, imagen 1 de 3 Samsung Gear 360 Speaker Replacement, Case: paso 1, imagen 2 de 3 Samsung Gear 360 Speaker Replacement, Case: paso 1, imagen 3 de 3
    • Twist silver ring on the lens counter-clockwise with force to remove it.
  2. Samsung Gear 360 Speaker Replacement: paso 2, imagen 1 de 2 Samsung Gear 360 Speaker Replacement: paso 2, imagen 2 de 2
    • Insert a small flathead screwdriver into marked slot on camera lens and pry off camera lens cover.
  3. Samsung Gear 360 Speaker Replacement: paso 3, imagen 1 de 2 Samsung Gear 360 Speaker Replacement: paso 3, imagen 2 de 2
    • Using a PH00 screwdriver head, remove all Phillips #00 0.75 mm screws on the front of the camera.
    • Repeat for the back side of the camera.
  4. Samsung Gear 360 Speaker Replacement: paso 4, imagen 1 de 3 Samsung Gear 360 Speaker Replacement: paso 4, imagen 2 de 3 Samsung Gear 360 Speaker Replacement: paso 4, imagen 3 de 3
    • Peel off the black rubber located on the bottom of the device using your hand or a small flathead screwdriver.
  5. Samsung Gear 360 Speaker Replacement: paso 5, imagen 1 de 2 Samsung Gear 360 Speaker Replacement: paso 5, imagen 2 de 2
    • Once the black rubber has been removed, unscrew all Phillips #00 0.75 mm screws on the bottom of the device using a PH00 screwdriver head.
  6. Samsung Gear 360 Speaker Replacement: paso 6, imagen 1 de 2 Samsung Gear 360 Speaker Replacement: paso 6, imagen 2 de 2
    • Using a plastic opening tool, pry the tripod mount off the device.
  7. Samsung Gear 360 Speaker Replacement: paso 7, imagen 1 de 2 Samsung Gear 360 Speaker Replacement: paso 7, imagen 2 de 2
    • Using both hands, carefully remove the right cover off the camera body.
  8. Samsung Gear 360 Speaker Replacement: paso 8, imagen 1 de 3 Samsung Gear 360 Speaker Replacement: paso 8, imagen 2 de 3 Samsung Gear 360 Speaker Replacement: paso 8, imagen 3 de 3
    • To remove the left cover of the camera body, lift the left cover using a small flathead screwdriver and pull it off.
  9. Samsung Gear 360 Speaker Replacement: paso 9, imagen 1 de 2 Samsung Gear 360 Speaker Replacement: paso 9, imagen 2 de 2
    • Once the camera body has been removed, lift and pull off the metal support ring using a small flathead screwdriver.
    • Repeat for both sides of the camera.
  10. Samsung Gear 360 Speaker Replacement: paso 10, imagen 1 de 2 Samsung Gear 360 Speaker Replacement: paso 10, imagen 2 de 2
    • Remove all Phillips #00 0.75 mm screws from the body of the camera using a PH00 screwdriver head.
  11. Samsung Gear 360 Speaker Replacement: paso 11, imagen 1 de 3 Samsung Gear 360 Speaker Replacement: paso 11, imagen 2 de 3 Samsung Gear 360 Speaker Replacement: paso 11, imagen 3 de 3
    • Carefully lift the three sensors off using a plastic opening tool and pull them aside.
  12. Samsung Gear 360 Speaker Replacement: paso 12, imagen 1 de 2 Samsung Gear 360 Speaker Replacement: paso 12, imagen 2 de 2
    • Carefully use a plastic opening tool to separate the gray case from the black case on the device.
  13. Samsung Gear 360 Speaker Replacement: paso 13, imagen 1 de 3 Samsung Gear 360 Speaker Replacement: paso 13, imagen 2 de 3 Samsung Gear 360 Speaker Replacement: paso 13, imagen 3 de 3
    • Insert a plastic removal tool underneath the four sensors on the motherboard to fully separate the camera case.
  14. Samsung Gear 360 Speaker Replacement, Speaker: paso 14, imagen 1 de 3 Samsung Gear 360 Speaker Replacement, Speaker: paso 14, imagen 2 de 3 Samsung Gear 360 Speaker Replacement, Speaker: paso 14, imagen 3 de 3
    • Within gold metal half of the case, unscrew the Phillips #00 0.75 mm screw located on the metal plate using a PH00 screwdriver.
    • Using a plastic opening tool, remove the metal cover.
  15. Samsung Gear 360 Speaker Replacement: paso 15, imagen 1 de 3 Samsung Gear 360 Speaker Replacement: paso 15, imagen 2 de 3 Samsung Gear 360 Speaker Replacement: paso 15, imagen 3 de 3
    • Using a PH000 screwdriver head, unscrew all Phillips #00 0.75 mm screws.
    • To remove the speaker from the device, use a plastic opening tool on the edge and gently lift it up.
Conclusión
Aidos Duisembayev
Miembro Desde 02/20/17
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S3-G5, Sullivan Spring 2017 Miembro de USF Tampa, Team S3-G5, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G5
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 397
