Introducción
This guide will show you how to remove the rear camera module from the Samsung Gear 360. Like the front camera, this module can be removed by completing a tear-down of the device, and unscrewing the module from there.
Qué necesitas
Within the grey half of the case, unscrew both Phillips #00 0.75 mm screws located on the metal plate using PH00 screwdriver.
2 personas más completaron esta guía.
