Saltar al contenido principal
Introducción
This guide will walk you through the process of replacing a dead or damaged battery in a Samsung Gear 360.
  1. Samsung Gear 360 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Insert thumb under tab of battery cover.
    • Pull to remove the battery cover.
  2. Samsung Gear 360 Battery Replacement: paso 2, imagen 1 de 2 Samsung Gear 360 Battery Replacement: paso 2, imagen 2 de 2
    • Once the cover is opened, press index finger on the tab to release the battery from the battery slot.
  3. Samsung Gear 360 Battery Replacement: paso 3, imagen 1 de 1
    • Once the battery has popped out, pull the battery out of the camera.
Conclusión
Una persona más ha completado esta guía.
Angel Veras
Miembro Desde 20/02/17
104 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S3-G5, Sullivan Spring 2017 Miembro de USF Tampa, Team S3-G5, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G5
4 Miembros
14 Guías creadas
Un comentario
I charged one battery successfully and proceeded to remove the battery and insert another battery to charge. The camera died and would not charge the second battery, so I re-inserted the charged battery and now the camera will not power up. Any ideas?
Mark Newsom - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 87
Todo El Tiempo: 5,457
