Introducción
This guide will walk you through the process of replacing a broken home button in a Samsung Gear 2.
Qué necesitas
To remove each strap, locate the metal latches on both sides of the back of the Gear.
Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
Pry the device open from the other side also if it does not fully disassemble from one side.
Locate the rectangular metal connector that attaches the camera to the Gear.
Use tweezers to gently lift and detach the metal plate of the connector.
Use tweezers to grab and then gently lift up the metal plate of the safety belt.
Insert the spudger into the small opening underneath the black home button assembly and pry it off the casing.
Lift up to detach the black assembly.
2 personas más completaron esta guía.
