Saltar al contenido principal
Samsung Gear 2 Camera Replacement
Qué necesitas
  1. Samsung Gear 2 Camera Replacement, Front half and Back half: paso 1, imagen 1 de 2 Samsung Gear 2 Camera Replacement, Front half and Back half: paso 1, imagen 2 de 2
    • Before disassembling your Gear, be sure it is powered off.
    • To remove each strap, locate the metal latches on both sides of the back of the Gear.
    • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
  2. Samsung Gear 2 Camera Replacement: paso 2, imagen 1 de 1
    • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
  3. Samsung Gear 2 Camera Replacement: paso 3, imagen 1 de 3 Samsung Gear 2 Camera Replacement: paso 3, imagen 2 de 3 Samsung Gear 2 Camera Replacement: paso 3, imagen 3 de 3
    • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
    • Pry the device open from the other side also if it does not fully disassemble from one side.
  4. Samsung Gear 2 Camera Replacement, Camera: paso 4, imagen 1 de 2 Samsung Gear 2 Camera Replacement, Camera: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Locate the rectangular metal connector that attaches the camera to the Gear.
    • Use tweezers to gently lift and detach the metal plate of the connector.
    • When reassembling the Gear, reattach the camera connector by carefully aligning the metal plate and its pins to its original placement. Make sure it snaps in place to avoid improper connections and possible damage.
  5. Samsung Gear 2 Camera Replacement: paso 5, imagen 1 de 1
    • Use tweezers to carefully lift the camera from its slot out of the case.
Conclusión
2 personas más completaron esta guía.
Allison Michel
Miembro Desde 04/14/14
513 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 13-27, Maness Spring 2014 Miembro de Cal Poly, Team 13-27, Maness Spring 2014
CPSU-MANESS-S14S13G27
4 Miembros
6 Guías creadas
Un comentario
Hey cool! Were can i buy the camara?
jorge - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 3,677
