Introducción
Replace the LCD in your Galaxy Xcover.
  1. Here is the Samsung Galaxy Xcover, with the LCD broken, that will be replaced.
    • Here is the Samsung Galaxy Xcover, with the LCD broken, that will be replaced.
  2. The first step, is remove the battery door. It comes with a security lock, that has to be on open position. Start opening from bottom, and releasing from the side edges.
    • The first step, is remove the battery door. It comes with a security lock, that has to be on open position. Start opening from bottom, and releasing from the side edges.
  3. Remove with a flat screwdriver, the volume button and the power button Now, with a Phillpis Screwdriver, remove all the screws from the backcover.
    • Remove with a flat screwdriver, the volume button and the power button
    • Now, with a Phillpis Screwdriver, remove all the screws from the backcover.
  4. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  5. With a flat screwdriver or plastic opener,  separate the front case from the rear case. It will be easy! With a flat screwdriver or plastic opener,  separate the front case from the rear case. It will be easy!
    • With a flat screwdriver or plastic opener, separate the front case from the rear case. It will be easy!
  6. Remove the screw on the lower zone of the main board. The screw is the same of the case, so dont worry if you mix them. Now, with a pliers, unplug the camera and the front speaker. Now, we are going to lift the main board, but ... be careful, below is the LCD flex cable!
    • Remove the screw on the lower zone of the main board. The screw is the same of the case, so dont worry if you mix them.
    • Now, with a pliers, unplug the camera and the front speaker. Now, we are going to lift the main board, but ...
    • be careful, below is the LCD flex cable!
  7. Remove the LCD flat cable, and then, remove the 2 screws on the sides of the front cover. They are the same as the others screws... Now, you can take apart the chassis from the front cover, leaving only the display and the touch.
    • Remove the LCD flat cable, and then, remove the 2 screws on the sides of the front cover. They are the same as the others screws...
    • Now, you can take apart the chassis from the front cover, leaving only the display and the touch.
  8. Lift up the black retainer, and take off the touch flex cable. Be careful, the flex has double side tape below the IC.
    • Lift up the black retainer, and take off the touch flex cable.
    • Be careful, the flex has double side tape below the IC.
    • Now, with a knife or cutter, lift carefully the LCD unit. Place the new LCD, and reassembly the phone.
    • In the near future, I´ll post how to replace the touch screen!
Conclusión
Una persona más ha completado esta guía.
Jaime
Miembro Desde 05/11/13
3,150 Reputación
4 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 21
Todo El Tiempo: 5,137
