Saltar al contenido principal
Samsung Galaxy View Motherboard Replacement
Qué necesitas
  1. Samsung Galaxy View Motherboard Replacement, Kickstand: paso 1, imagen 1 de 1
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Motherboard Replacement: paso 2, imagen 1 de 3 Samsung Galaxy View Motherboard Replacement: paso 2, imagen 2 de 3 Samsung Galaxy View Motherboard Replacement: paso 2, imagen 3 de 3
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
  3. Samsung Galaxy View Motherboard Replacement, Battery: paso 3, imagen 1 de 2 Samsung Galaxy View Motherboard Replacement, Battery: paso 3, imagen 2 de 2
    • Check the device is completely turned off.
    • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
  4. Samsung Galaxy View Motherboard Replacement: paso 4, imagen 1 de 3 Samsung Galaxy View Motherboard Replacement: paso 4, imagen 2 de 3 Samsung Galaxy View Motherboard Replacement: paso 4, imagen 3 de 3
    • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
  5. Samsung Galaxy View Motherboard Replacement: paso 5, imagen 1 de 3 Samsung Galaxy View Motherboard Replacement: paso 5, imagen 2 de 3 Samsung Galaxy View Motherboard Replacement: paso 5, imagen 3 de 3
    • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
    • Insert the metal spudger within the opening.
    • Move the metal spudger down the seam, prying the back panel open as you go.
    • Once a large enough opening is made, pry the entire back panel off with your hand.
    • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
  6. Samsung Galaxy View Motherboard Replacement: paso 6, imagen 1 de 2 Samsung Galaxy View Motherboard Replacement: paso 6, imagen 2 de 2
    • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
  7. Samsung Galaxy View Motherboard Replacement: paso 7, imagen 1 de 3 Samsung Galaxy View Motherboard Replacement: paso 7, imagen 2 de 3 Samsung Galaxy View Motherboard Replacement: paso 7, imagen 3 de 3
    • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  8. Samsung Galaxy View Motherboard Replacement, Speakers: paso 8, imagen 1 de 3 Samsung Galaxy View Motherboard Replacement, Speakers: paso 8, imagen 2 de 3 Samsung Galaxy View Motherboard Replacement, Speakers: paso 8, imagen 3 de 3
    • Use the plastic opening tool to disconnect the white bundled cable connector that links the left speaker to the motherboard via a red wire.
    • Remove the left speaker by gripping it with your hand and lifting it off of the pegs.
  9. Samsung Galaxy View Motherboard Replacement: paso 9, imagen 1 de 2 Samsung Galaxy View Motherboard Replacement: paso 9, imagen 2 de 2
    • Remove the right speaker by gripping it with your hand and pulling it straight up and off of the pegs.
    • The white bundled wire connector, and the red wire attaching the speaker to the motherboard, will come off when lifting the speaker.
  10. Samsung Galaxy View Motherboard Replacement, Motherboard: paso 10, imagen 1 de 2 Samsung Galaxy View Motherboard Replacement, Motherboard: paso 10, imagen 2 de 2
    • Insert the plastic opening tool beneath the orange press-fit connector attached to the bottom left side of the motherboard and use a leverage motion to pry the connector from the board.
    • Repeat the above step for the other two orange press-fit connectors attached on the bottom left side of the motherboard.
  11. Samsung Galaxy View Motherboard Replacement: paso 11, imagen 1 de 2 Samsung Galaxy View Motherboard Replacement: paso 11, imagen 2 de 2
    • Use the plastic opening tool to pry up on the blue antenna cable connector near the right edge of the motherboard.
    • Repeat the above for the black antenna cable connector positioned next to the blue wire.
  12. Samsung Galaxy View Motherboard Replacement: paso 12, imagen 1 de 3 Samsung Galaxy View Motherboard Replacement: paso 12, imagen 2 de 3 Samsung Galaxy View Motherboard Replacement: paso 12, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the nine 3 mm screws around the motherboard.
    • There is a metal bracket beneath four of the screws on the right side of motherboard. This bracket will also be removed during this step.
  13. Samsung Galaxy View Motherboard Replacement: paso 13, imagen 1 de 1
    • Lift the motherboard straight up to remove it from the device.
Conclusión
16 personas más completaron esta guía.
Equipo
Cal Poly, Team 4-5, Livingston Fall 2016 Miembro de Cal Poly, Team 4-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G5
4 Miembros
12 Guías creadas
5 comentarios
Hi… Where can I get a replacement motherboard for a Samsung galaxy view? I need one.
Ryan Mitchell - Contestar
DITTO that I need a new mother board as well. Where can we purchase it?
Lori Marr - Contestar
Hello I need the charger plugin and wire harness replacement parts. there tiny heres a screen shot of what is needed. If anyone knows where please posts info in reply thank you
[img]https://i.imgur.com/QMgrXkh.jpg[/img]
wildcar - Contestar
where can you find a replacement motherboard. seems like all you can you is buy a used one off ebay.
chiming tse - Contestar
where can you buy a replacement motherboard. seems like only way is to buy a used unit off ebay.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 58
Todo El Tiempo: 6,906
