Saltar al contenido principal
Samsung Galaxy View Kickstand Replacement
Qué necesitas
  1. Samsung Galaxy View Kickstand Replacement, Kickstand: paso 1, imagen 1 de 1
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Kickstand Replacement: paso 2, imagen 1 de 3 Samsung Galaxy View Kickstand Replacement: paso 2, imagen 2 de 3 Samsung Galaxy View Kickstand Replacement: paso 2, imagen 3 de 3
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
Conclusión
5 personas más completaron esta guía.
Jordan Thayer
Miembro Desde 10/06/16
527 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 4-5, Livingston Fall 2016 Miembro de Cal Poly, Team 4-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G5
4 Miembros
12 Guías creadas
15 comentarios
Where do u buy a replacement kickstand
Bethann Stokes - Contestar
The only thing I could find was a broken one on eBay for parts ......
cindylou73 -
I have the same issue! kickstand broke in half (it fell and got broken) and cannot find replacement
Carlos Sierra -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 37
Todo El Tiempo: 8,688
