Saltar al contenido principal
Samsung Galaxy View Camera Replacement
Qué necesitas
  1. Samsung Galaxy View Camera Replacement, Kickstand: paso 1, imagen 1 de 1
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Camera Replacement: paso 2, imagen 1 de 3 Samsung Galaxy View Camera Replacement: paso 2, imagen 2 de 3 Samsung Galaxy View Camera Replacement: paso 2, imagen 3 de 3
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
  3. Samsung Galaxy View Camera Replacement, Battery: paso 3, imagen 1 de 2 Samsung Galaxy View Camera Replacement, Battery: paso 3, imagen 2 de 2
    • Check the device is completely turned off.
    • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
  4. Samsung Galaxy View Camera Replacement: paso 4, imagen 1 de 3 Samsung Galaxy View Camera Replacement: paso 4, imagen 2 de 3 Samsung Galaxy View Camera Replacement: paso 4, imagen 3 de 3
    • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
  5. Samsung Galaxy View Camera Replacement: paso 5, imagen 1 de 3 Samsung Galaxy View Camera Replacement: paso 5, imagen 2 de 3 Samsung Galaxy View Camera Replacement: paso 5, imagen 3 de 3
    • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
    • Insert the metal spudger within the opening.
    • Move the metal spudger down the seam, prying the back panel open as you go.
    • Once a large enough opening is made, pry the entire back panel off with your hand.
    • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
  6. Samsung Galaxy View Camera Replacement: paso 6, imagen 1 de 2 Samsung Galaxy View Camera Replacement: paso 6, imagen 2 de 2
    • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
  7. Samsung Galaxy View Camera Replacement: paso 7, imagen 1 de 3 Samsung Galaxy View Camera Replacement: paso 7, imagen 2 de 3 Samsung Galaxy View Camera Replacement: paso 7, imagen 3 de 3
    • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  8. Samsung Galaxy View Camera Replacement, Camera: paso 8, imagen 1 de 3 Samsung Galaxy View Camera Replacement, Camera: paso 8, imagen 2 de 3 Samsung Galaxy View Camera Replacement, Camera: paso 8, imagen 3 de 3
    • Place the plastic opening tool underneath the blue press-fit connector which is touching the green circuit board at the bottom of the device.
    • Pry upwards with the plastic opening tool to disconnect the press-fit connector.
    • Remove the camera by carefully gripping the press-fit connector and pulling upwards.
Conclusión
Una persona más ha completado esta guía.
Jordan Thayer
Miembro Desde 10/06/16
527 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 4-5, Livingston Fall 2016 Miembro de Cal Poly, Team 4-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G5
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 1,022
