Saltar al contenido principal
Samsung Galaxy Victory 4G Motherboard Replacement
Qué necesitas
  1. Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Place phone face down. Ensure the side with the display screen is not facing you.
    • Locate battery door and slide open.
    • Remove battery.
  2. Samsung Galaxy Victory 4G Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the 7 Phillips 3.93 mm labeled screws by using the Phillips #00 Precision Screwdriver.
  3. Samsung Galaxy Victory 4G Motherboard Replacement: paso 3, imagen 1 de 1
    • Use the plastic opening tool to pry open the back cover.
    • Insert the tool into the SD card slot and pry around the entire phone.
  4. Samsung Galaxy Victory 4G Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove one Phillips 3.93 mm screw from bottom center of the phone.
  5. Samsung Galaxy Victory 4G Motherboard Replacement: paso 5, imagen 1 de 3 Samsung Galaxy Victory 4G Motherboard Replacement: paso 5, imagen 2 de 3 Samsung Galaxy Victory 4G Motherboard Replacement: paso 5, imagen 3 de 3
    • Carefully disconnect 3 ribbons at the shown location. To remove, place tool under the ribbon and pull slowly to avoid tearing.
  6. Samsung Galaxy Victory 4G Motherboard Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Victory 4G Motherboard Replacement: paso 6, imagen 2 de 2
    • Pull the motherboard back and out to the left. Make sure the motherboard is faced straight up, as shown in the photo.
    • Place your tool under the labeled area and pull gently to detach the ribbon cable from the motherboard.
    • At this point the motherboard should be completely detached from the rest of the phone.
Conclusión
6 personas más completaron esta guía.
Zhao
Miembro Desde 09/23/14
251 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 15-3, Remmell Fall 2014 Miembro de USF Tampa, Team 15-3, Remmell Fall 2014
USFT-REMMELL-F14S15G3
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,581
