Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Galaxy TabPro S Rear Facing Camera Replacement
Qué necesitas
  1. Samsung Galaxy TabPro S Rear Facing Camera Replacement, Rear Facing Camera: paso 1, imagen 1 de 1
    • Place the device face down on a flat work surface.
    Pregunta a FixBot
    Agregar Comentario
  2. Samsung Galaxy TabPro S Rear Facing Camera Replacement: paso 2, imagen 1 de 2 Samsung Galaxy TabPro S Rear Facing Camera Replacement: paso 2, imagen 2 de 2
    • Heat the iOpener in the microwave for 30 seconds. Then place it on each side for 20 seconds in order to loosen the adhesive sealing on the device.
    Pregunta a FixBot
    Agregar Comentario
  3. Samsung Galaxy TabPro S Rear Facing Camera Replacement: paso 3, imagen 1 de 3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: paso 3, imagen 2 de 3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: paso 3, imagen 3 de 3
    • Using the plastic spudger, open up the back of the device.
    Pregunta a FixBot
    Agregar Comentario
  4. Samsung Galaxy TabPro S Rear Facing Camera Replacement: paso 4, imagen 1 de 1
    • Locate the camera and its corresponding connecting port.
    Pregunta a FixBot
    Agregar Comentario
  5. Samsung Galaxy TabPro S Rear Facing Camera Replacement: paso 5, imagen 1 de 3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: paso 5, imagen 2 de 3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Using tweezers carefully peel off the sticker.
    Pregunta a FixBot
    Agregar Comentario
  6. Samsung Galaxy TabPro S Rear Facing Camera Replacement: paso 6, imagen 1 de 2 Samsung Galaxy TabPro S Rear Facing Camera Replacement: paso 6, imagen 2 de 2
    • Using the black nylon spudger, flip the top half of the connecting port downward until you hear a click.
    Pregunta a FixBot
    Agregar Comentario
  7. Samsung Galaxy TabPro S Rear Facing Camera Replacement: paso 7, imagen 1 de 1
    • Proceed to lift up the camera out of its resting position.
    Pregunta a FixBot
    Agregar Comentario
  8. Samsung Galaxy TabPro S Rear Facing Camera Replacement: paso 8, imagen 1 de 2 Samsung Galaxy TabPro S Rear Facing Camera Replacement: paso 8, imagen 2 de 2
    • Simply pull the camera parallel to the device out of its connecting port.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Jyotsna Gone
Miembro Desde 02/20/17
515 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-2, Sullivan Spring 2017 Miembro de USF Tampa, Team 1-2, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G2
Miembros de 4
2 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 30
Todo El Tiempo: 1,848
