Saltar al contenido principal
Samsung Galaxy Tab S3 Motherboard Replacement
Qué necesitas
  1. Samsung Galaxy Tab S3 Motherboard Replacement, Display: paso 1, imagen 1 de 1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Samsung Galaxy Tab S3 Motherboard Replacement: paso 2, imagen 1 de 1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. Samsung Galaxy Tab S3 Motherboard Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  4. Samsung Galaxy Tab S3 Motherboard Replacement: paso 4, imagen 1 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 4, imagen 2 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 4, imagen 3 de 3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Motherboard Replacement, Rear glass panel: paso 5, imagen 1 de 2 Samsung Galaxy Tab S3 Motherboard Replacement, Rear glass panel: paso 5, imagen 2 de 2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
  6. Samsung Galaxy Tab S3 Motherboard Replacement, Battery: paso 6, imagen 1 de 2 Samsung Galaxy Tab S3 Motherboard Replacement, Battery: paso 6, imagen 2 de 2
    • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
  7. Samsung Galaxy Tab S3 Motherboard Replacement: paso 7, imagen 1 de 1
    • The midframe should snap off from the device’s motherboard.
  8. Samsung Galaxy Tab S3 Motherboard Replacement: paso 8, imagen 1 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 8, imagen 2 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 8, imagen 3 de 3
    • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
  9. Samsung Galaxy Tab S3 Motherboard Replacement: paso 9, imagen 1 de 2 Samsung Galaxy Tab S3 Motherboard Replacement: paso 9, imagen 2 de 2
    • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
  10. Samsung Galaxy Tab S3 Motherboard Replacement: paso 10, imagen 1 de 2 Samsung Galaxy Tab S3 Motherboard Replacement: paso 10, imagen 2 de 2
    • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
  11. Samsung Galaxy Tab S3 Motherboard Replacement: paso 11, imagen 1 de 1
    • The battery should now be removed and detached from the device.
  12. Samsung Galaxy Tab S3 Motherboard Replacement, Motherboard: paso 12, imagen 1 de 3 Samsung Galaxy Tab S3 Motherboard Replacement, Motherboard: paso 12, imagen 2 de 3 Samsung Galaxy Tab S3 Motherboard Replacement, Motherboard: paso 12, imagen 3 de 3
    • Use the black nylon spudger to lift the gray ZIF connector up and pull out the orange ribbon cable below the camera.
  13. Samsung Galaxy Tab S3 Motherboard Replacement: paso 13, imagen 1 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 13, imagen 2 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 13, imagen 3 de 3
    • Remove the ribbon cable for the front facing camera after popping the red ZIF connector bar up with a spudger.
  14. Samsung Galaxy Tab S3 Motherboard Replacement: paso 14, imagen 1 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 14, imagen 2 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 14, imagen 3 de 3
    • Disconnect the three press fit connectors in the top section of the midframe by prying upwards with the spudger.
  15. Samsung Galaxy Tab S3 Motherboard Replacement: paso 15, imagen 1 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 15, imagen 2 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 15, imagen 3 de 3
    • Pull back the green tape on the upper section of the motherboard with your tweezers to reveal the ZIF connector below.
  16. Samsung Galaxy Tab S3 Motherboard Replacement: paso 16, imagen 1 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 16, imagen 2 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 16, imagen 3 de 3
    • Push the red bar up from the ZIF connector with the spudger and pull the orange, touchpad ribbon cable out.
  17. Samsung Galaxy Tab S3 Motherboard Replacement: paso 17, imagen 1 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 17, imagen 2 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 17, imagen 3 de 3
    • Use the spudger to disconnect five more press fit connectors on the left side of the motherboard by prying upwards.
  18. Samsung Galaxy Tab S3 Motherboard Replacement: paso 18, imagen 1 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 18, imagen 2 de 3 Samsung Galaxy Tab S3 Motherboard Replacement: paso 18, imagen 3 de 3
    • Pop the coaxial antenna cables off from the motherboard with the spudger.
  19. Samsung Galaxy Tab S3 Motherboard Replacement: paso 19, imagen 1 de 1
    • Using your fingers, move all the cables aside and wiggle the motherboard free.
Conclusión
3 personas más completaron esta guía.
Sarah Westberg
Miembro Desde 03/11/19
23,116 Reputación
70 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,767 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 10
Ultimos 30 días: 35
Todo El Tiempo: 3,583
