Saltar al contenido principal
Samsung Galaxy Tab S3 Display Replacement
Qué necesitas
  1. Samsung Galaxy Tab S3 Display Replacement, Display: paso 1, imagen 1 de 1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Samsung Galaxy Tab S3 Display Replacement: paso 2, imagen 1 de 1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. Samsung Galaxy Tab S3 Display Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  4. Samsung Galaxy Tab S3 Display Replacement: paso 4, imagen 1 de 3 Samsung Galaxy Tab S3 Display Replacement: paso 4, imagen 2 de 3 Samsung Galaxy Tab S3 Display Replacement: paso 4, imagen 3 de 3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Display Replacement, Rear glass panel: paso 5, imagen 1 de 2 Samsung Galaxy Tab S3 Display Replacement, Rear glass panel: paso 5, imagen 2 de 2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
Conclusión
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
7 personas más completaron esta guía.
Jelly Romero
Miembro Desde 04/19/18
322 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S22-G4, Maness Spring 2018 Miembro de Cal Poly, Team S22-G4, Maness Spring 2018
CPSU-MANESS-S18S22G4
5 Miembros
15 Guías creadas
5 comentarios
Thank you so much, It helped me so much.
MRxROBOT - Contestar
What if the digitizer is ok and only the glass cover is cracked
stargazer_jbl - Contestar
if you need more adhesive what is the right type to buy? Want to have some on hand before I open my S3 up.
jnorr - Contestar
If my screen freezing exactly half, can that be the connection cable damaged.? It's look like it happens every time I touch or hold the corner where the volume and power buttons are. Never dropped it.
Lena Clark - Contestar
I also have the same issue
How your issue was resolved.
Ashwin -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 31
Ultimos 30 días: 165
Todo El Tiempo: 26,518
