Saltar al contenido principal
Samsung Galaxy Tab S2 Camera Replacement
Qué necesitas
  1. Samsung Galaxy Tab S2 Camera Replacement, Screen: paso 1, imagen 1 de 1
    • Working on your device while it is turned on may result in an electric shock. Be sure to shut down and unplug your device before you begin.
    • Removing the screen may be difficult due to strong adhesives.
    • Apply heat to all the seams of the device using an iFixit iOpener or heat gun in order to loosen the adhesive around the edges of the screen.
  2. Samsung Galaxy Tab S2 Camera Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab S2 Camera Replacement: paso 2, imagen 2 de 2
    • Insert the plastic opening tool into the gap on the side of the tablet, near a corner where you want to start removing the screen.
    • Place the small suction cup on the screen near the corner that the plastic opening tool is placed.
    • Lift the small suction cup up while pushing down with the plastic opening tool to remove screen (you may need to have someone else hold the device down for proper leverage).
    • A ribbon cable is attached to the back of the screen. Avoid lifting or moving the screen more than 3-4 inches before disconnecting the ribbon cable or you could damage the device.
  3. Samsung Galaxy Tab S2 Camera Replacement: paso 3, imagen 1 de 1
    • A piece of silver tape is placed over the gold ribbon cable connecting the screen to the tablet.
    • Use the tweezers to carefully remove the silver tape.
  4. Samsung Galaxy Tab S2 Camera Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Tab S2 Camera Replacement: paso 4, imagen 2 de 2
    • With the plastic opening tool gently lift to disconnect the gold ribbon cable that attaches the screen to the base tablet.
  5. Samsung Galaxy Tab S2 Camera Replacement, Panel Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Tab S2 Camera Replacement, Panel Replacement: paso 5, imagen 2 de 2
    • Remove the nineteen 3mm Phillips #1 screws.
  6. Samsung Galaxy Tab S2 Camera Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Tab S2 Camera Replacement: paso 6, imagen 2 de 2
    • Pry open the next layer of the device using the plastic opening tool.
    • Even though the device separates along the outside edge, using the inside edge (as pictured) may help with leverage.
  7. Samsung Galaxy Tab S2 Camera Replacement, Camera: paso 7, imagen 1 de 1
    • Remove strip of green tape covering the camera connector with the tweezers.
  8. Samsung Galaxy Tab S2 Camera Replacement: paso 8, imagen 1 de 1
    • Use tweezers to lift the tab on the ZIF connector holding the ribbon cable in place.
    • Pull the ribbon cable straight out with tweezers.
  9. Samsung Galaxy Tab S2 Camera Replacement: paso 9, imagen 1 de 2 Samsung Galaxy Tab S2 Camera Replacement: paso 9, imagen 2 de 2
    • Remove rear camera.
Conclusión
Jovina Martinez
Miembro Desde 01/20/16
2,049 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 10-4, Remmell Spring 2016 Miembro de USF Tampa, Team 10-4, Remmell Spring 2016
USFT-REMMELL-S16S10G4
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 2,227
