Introducción
Replacement of the motherboard requires removal of a few other components first. See the prerequisite guides before attempting just the motherboard.
Qué necesitas
Heat the iOpeners in a microwave for 1-2 minutes.
Place heated iOpeners on screen edges to heat the adhesive.
Remove the 17 silver 3.0 mm Phillips head screws located around the edge of the device using the screwdriver.
Using the screwdriver, remove the 4 black 3.0 mm Phillips head screws located on the upper and lower motherboard.
9 personas más completaron esta guía.
2 comentarios
Very understandable, thank you very much! From the Philippines!
