Saltar al contenido principal
Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement
Qué necesitas
  1. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Back Cover: paso 1, imagen 1 de 2 Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Back Cover: paso 1, imagen 2 de 2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement: paso 2, imagen 1 de 1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement: paso 3, imagen 1 de 1
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Rear Facing Camera: paso 4, imagen 1 de 2 Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Rear Facing Camera: paso 4, imagen 2 de 2
    • Gently pry the camera connector away from the motherboard with a plastic opening tool or your fingers.
    • Lift the rear-facing camera module up and away from the device.
Conclusión
2 personas más completaron esta guía.
Trent Chapman
Miembro Desde 10/01/15
1,378 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 12-15, Maness Fall 2015 Miembro de Cal Poly, Team 12-15, Maness Fall 2015
CPSU-MANESS-F15S12G15
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 1,439
