Saltar al contenido principal
Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement
Qué necesitas
  1. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Back Cover: paso 1, imagen 1 de 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Back Cover: paso 1, imagen 2 de 2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: paso 2, imagen 1 de 1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: paso 3, imagen 1 de 1
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Headphone Jack/Speakers Assembly: paso 4, imagen 1 de 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Headphone Jack/Speakers Assembly: paso 4, imagen 2 de 2
    • Remove the two 2 mm Phillips #000 securing the headphone jack.
  5. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: paso 5, imagen 1 de 1
    • Disconnect the blue connector by gently popping it off of the motherboard with a plastic opening tool.
  6. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: paso 6, imagen 2 de 2
    • Use the metal spudger to pry from the top left corner of the headphone jack/lower speaker assembly.
    • Gently lift the headphone jack/lower speaker assembly free of the device.
  7. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: paso 7, imagen 1 de 1
    • Locate the top speaker.
    • Use a plastic opening tool to disconnect the green-gold upper speaker connector from the motherboard.
  8. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: paso 8, imagen 1 de 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: paso 8, imagen 2 de 2
    • Use a spudger to pry the uper speaker up and away from the device.
Conclusión
8 personas más completaron esta guía.
Trent Chapman
Miembro Desde 10/01/15
1,360 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 12-15, Maness Fall 2015 Miembro de Cal Poly, Team 12-15, Maness Fall 2015
CPSU-MANESS-F15S12G15
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 3,184
