Saltar al contenido principal
Samsung Galaxy Tab Pro 8.4 Motherboard Replacement
Qué necesitas
  1. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: paso 2, imagen 2 de 2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: paso 3, imagen 1 de 2 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: paso 4, imagen 1 de 1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: paso 5, imagen 1 de 1
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: paso 6, imagen 1 de 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: paso 6, imagen 2 de 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: paso 6, imagen 3 de 3
    • Remove all the clips that are attached to the motherboard using your fingers or a nylon spudger.
  7. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: paso 7, imagen 1 de 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: paso 7, imagen 2 de 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: paso 7, imagen 3 de 3
    • There are four Phillips head screws (2.5mm) that need to be removed:
    • Two on the charging port, which is the small metallic piece at the bottom of the device.
    • There is one screw that is covered by a small green tape. The tape must be peeled off before the screw under can be removed.
    • The last screw is found on a speaker at the bottom right of the device. Once the screw is removed, the speaker must be removed as well.
  8. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: paso 8, imagen 1 de 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: paso 8, imagen 2 de 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: paso 8, imagen 3 de 3
    • There is a small wire that connects the motherboard to the bottom right corner.
    • Gently pull the end of the wire that attaches the motherboard to the device until the wire is disconnected.
    • After the cord is disconnected, the motherboard can be removed from the tablet by simply lifting it from the device.
Linea de Meta
5 personas más completaron esta guía.
victor johnson
Miembro Desde 10/05/16
242 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 9-2, Lacy Fall 2016 Miembro de USF Tampa, Team 9-2, Lacy Fall 2016
USFT-LACY-F16S9G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 2,393
