Saltar al contenido principal
Samsung Galaxy Tab Pro 8.4 Battery Replacement
Qué necesitas
  1. Samsung Galaxy Tab Pro 8.4 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Battery Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab Pro 8.4 Battery Replacement: paso 2, imagen 2 de 2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Battery Replacement: paso 3, imagen 1 de 2 Samsung Galaxy Tab Pro 8.4 Battery Replacement: paso 3, imagen 2 de 2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Battery Replacement: paso 4, imagen 1 de 1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Battery Replacement: paso 5, imagen 1 de 1
    • The battery should be completely disconnected and the new one can be installed.
Conclusión
21 personas más completaron esta guía.
Jonathan Romine
Miembro Desde 09/12/16
1,072 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 9-2, Lacy Fall 2016 Miembro de USF Tampa, Team 9-2, Lacy Fall 2016
USFT-LACY-F16S9G2
4 Miembros
10 Guías creadas
Un comentario
Samsung Galaxy tab ki battery 4800 mah
Razwan good ashqui - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 37
Todo El Tiempo: 12,169
