Saltar al contenido principal
Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement
Qué necesitas
  1. Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement, Rear Panel: paso 1, imagen 1 de 2 Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement, Rear Panel: paso 1, imagen 2 de 2
    • Be gentle, the front panel is connected to sensitive wiring that may snap if too much pressure is applied.
    • Insert a plastic opening tool into the crevice between the screen and the side of the tablet.
    • Go around the entire crevice with the plastic opening tool.
    • Set aside the separated front and rear panels of the device.
  2. Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement, Front Facing Camera: paso 2, imagen 1 de 3 Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement, Front Facing Camera: paso 2, imagen 2 de 3 Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement, Front Facing Camera: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use plastic tweezers to carefully detach the front-facing camera from the motherboard.
Conclusión
3 personas más completaron esta guía.
Stephen Yeung
Miembro Desde 08/26/15
1,547 Reputación
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 1,080
