Saltar al contenido principal
Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement
Qué necesitas
  1. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Rear Case: paso 1, imagen 1 de 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Rear Case: paso 1, imagen 2 de 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Rear Case: paso 1, imagen 3 de 3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: paso 2, imagen 2 de 2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Motherboard: paso 3, imagen 1 de 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Motherboard: paso 3, imagen 2 de 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Motherboard: paso 3, imagen 3 de 3
    • Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: paso 4, imagen 2 de 2
    • Use the plastic opening tool to lift the ZIF (zero insertion force) connector holding the ribbon cable.
    • Pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: paso 5, imagen 2 de 2
    • Use the plastic opening tool to lift up the latch to the ribbon cable.
    • Remove the ribbon cable from the connector.
  6. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: paso 6, imagen 1 de 1
    • Remove the seven 4mm PH000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: paso 7, imagen 1 de 1
    • Use the plastic opening tool to pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: paso 8, imagen 1 de 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: paso 8, imagen 2 de 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard out of the case.
  9. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Charging Port: paso 9, imagen 1 de 2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Charging Port: paso 9, imagen 2 de 2
    Comprar
    • Use a soldering iron to heat 4 spots of solder from the motherboard.
    • To learn more about soldering, check out iFixit's soldering technique guide.
    • Use precision tweezers to remove the charging port.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S19-G2, Hoffman Spring 2017 Miembro de USF Tampa, Team S19-G2, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G2
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 6,603
