Saltar al contenido principal
Samsung Galaxy Tab E Lite 7 Kids Battery Replacement
Qué necesitas
  1. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: paso 1, imagen 1 de 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: paso 1, imagen 2 de 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: paso 1, imagen 3 de 3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: paso 2, imagen 2 de 2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: paso 3, imagen 1 de 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: paso 3, imagen 2 de 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: paso 3, imagen 3 de 3
    • Use the plastic opening tool to gently lift the black ZIF (zero insertion force) connector shown within the red circle.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: paso 4, imagen 2 de 2
    • Use the plastic opening tool to gently lift black ZIF (zero insertion force) connector shown within the red square.
    • Now gently pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: paso 5, imagen 1 de 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: paso 5, imagen 2 de 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: paso 5, imagen 3 de 3
    • Use the plastic opening tool and gently pry out the battery from the left-hand side.
    • Grab the battery and lift it up.
Conclusión
5 personas más completaron esta guía.
Equipo
USF Tampa, Team S19-G2, Hoffman Spring 2017 Miembro de USF Tampa, Team S19-G2, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G2
4 Miembros
7 Guías creadas
Un comentario
Great information.  You need to show how to replace a screen- LCD for a Samsung Galaxy TAB E Lite Kids.
Paul McWilliams - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 3,026
