Introducción
This procedure is relatively straight forward. You should take care to place the display on a soft surface and it is always advisable to use an anti-static bracelet, or an antistatic station to protect delicate circuitry from static discharge.
Partes
Resumen del Video
Insert one of the blue plastic opening tools between the glass display and the edge of the tablet's outer shell to break the seal around the display. It doesn't matter where you start the process, but once you form a gap, continue opening the gap around the edge of the device.
The display assembly and back casing should gently come apart after a gap is formed around the perimeter.
Attached to the back side of the display you will find the all of the primary computer hardware including the battery. You will need to remove six 3-millimeter Phillips head PH000 screws and two ribbon cables.
The first ribbon cable to remove is the longer of the two. It overlaps the entire battery. It is marked in orange in the Step 2 image.
Using the precision tweezers gently remove the green tape over the clip at the end of the ribbon cable.
Last, gently lift the clip lever and the ribbon cable should should easily slide out from its slot.
Once all the 6 screws and 2 ribbons are removed, the battery should come free of the display assembly very easily.
With one hand on each side of the tablet simply turn the device on edge with one hand and tilt it over until the battery falls into your other hand.
If for some reason the battery does not come out, double check to ensure you have removed and unattached all of the 6 screws and 2 ribbon cables.
23 personas más completaron esta guía.
8 comentarios
Here are some tips to pry the cover off without damaging the digitizer: the cover is cemented with adhesive tape, making it hard to insert a tool into the seam, so heat the edge only first. Once you have it warm (not hot), use all of your fingers on the power button side to pull the plastic edge, using your thumbs to press on the back - do not try to pry or press against the glass side. Also, do not slide the pry tool under the glass and lift up, you can crack the glass. It takes patience
First step is not easy. Do what seadawg did above. Dont bother with plastic tools. Start near the power button. Dont try to go between the screen and tablet. Pull back the plastic instead. I wish I had read seadawgs advice first, would have saved me a digitiser and a load of time…
Where do u even get the tools? also how is this supposed to work if everyones saying it will crack the screen?
Heat gun available at most any hardware store, walmart sells an electronics repair tool kit for $15 USD with all the other tools you'd ever need including the screwdriver bits for Nintendo products too!
