Saltar al contenido principal
Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement
Qué necesitas
  1. Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement, Back Casing: paso 1, imagen 1 de 1
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: paso 2, imagen 3 de 3
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: paso 3, imagen 1 de 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: paso 3, imagen 2 de 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: paso 3, imagen 3 de 3
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
  4. Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement, Front Camera: paso 4, imagen 1 de 1
    • The front camera is located at the top, middle of the motherboard. The red rectangle in the image to the left depicts its location.
  5. Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: paso 5, imagen 1 de 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: paso 5, imagen 2 de 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the ribbon wires connecting the camera to the motherboard by using tweezers to flip the black latch away from the camera (towards the bottom of the tablet).
    • Carefully pull the camera out.
Conclusión
Equipo
USF Tampa, Team 1-4, Cagle Fall 2016 Miembro de USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 743
