Saltar al contenido principal
Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement
Qué necesitas
  1. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement, Back Camera: paso 1, imagen 1 de 1
    • Make sure the device is turned off.
    • Using the plastic opening tool, start in the center and wedge the angled tip between the plastic back and the scree.
    • Try to pressure it, wedge it back and forth.
    • Do not wedge the plastic opening tool directly on top of the power buttons and headphone buttons.
  2. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: paso 2, imagen 2 de 2
    • Once the bottom edge has been loosened, use the suction tool to pull it.
    • The second picture shows the internal portion of the tablet once the back cover is removed.
  3. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: paso 3, imagen 1 de 2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: paso 3, imagen 2 de 2
    • The first picture shows the location of back camera.
    • Disconnect the rectangular connection from the back camera to the motherboard.
  4. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: paso 4, imagen 2 de 2
    • The picture illustrates what the device should look like once the back camera is removed.
Conclusión
Tingting Liu
Miembro Desde 09/28/16
25 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-4, Cagle Fall 2016 Miembro de USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 1,259
