Introducción
The screen of the Samsung Galaxy Tab E 8.0 may become damaged if the device is dropped or struck by a hard object. This guide shows how to replace the tablet's screen, which is attached to the front panel.
Qué necesitas
Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
Use an iOpener or a heat gun/hair dryer to warm the outer 1/2 inch of the screen. It should be very warm but not too hot to touch or you may cause heat damage to components inside the device.
Use the iFixit Opening Tool to get between the plastic screen and the device to pry off the screen.
6 personas más completaron esta guía.
Un comentario
I am working on a 7” lite E. Is the procedure about the same?
