Saltar al contenido principal
Samsung Galaxy Tab A Earphone Jack Replacement
Qué necesitas
  1. Samsung Galaxy Tab A Earphone Jack Replacement, Earphone Jack: paso 1, imagen 1 de 1
    • Make sure the device is turned off before attempting to disassemble it.
    • At the top portion of the memory card slot, use the small metal spudger to create separation between the back cover and the rest of the device.
    • The small metal spudger is only used to create separation between the back cover and the rest of the device, not to remove the back cover.
  2. Samsung Galaxy Tab A Earphone Jack Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab A Earphone Jack Replacement: paso 2, imagen 2 de 2
    • Use the intermediate metal spudger in place of the small metal spudger to remove the back cover. This is done by sliding the intermediate metal spudger around the perimeter of the device, beginning at the top portion of the memory card slot.
    • The second picture shows the internal portion of the device once the back cover is removed.
  3. Samsung Galaxy Tab A Earphone Jack Replacement: paso 3, imagen 1 de 2 Samsung Galaxy Tab A Earphone Jack Replacement: paso 3, imagen 2 de 2
    • Use the spudger to disconnect the earphone jack from the motherboard.
    • To prevent any damage to either the earphone jack or motherboard, it is recommend to remove the jack at its blue rubber portion.
    • The connected and disconnected earphone jack is shown in the first and second picture, respectively.
  4. Samsung Galaxy Tab A Earphone Jack Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Tab A Earphone Jack Replacement: paso 4, imagen 2 de 2
    • Use the PH0 screwdriver bit to remove the 2.5 mm screws attaching earphone jack to the rest of the device.
    • The second picture shows this process in action.
  5. Samsung Galaxy Tab A Earphone Jack Replacement: paso 5, imagen 1 de 3 Samsung Galaxy Tab A Earphone Jack Replacement: paso 5, imagen 2 de 3 Samsung Galaxy Tab A Earphone Jack Replacement: paso 5, imagen 3 de 3
    • Use the spudger to fully remove the earphone jack from the rest of the device.
    • The second picture shows what the device should look like once the earphone jack has been removed.
Conclusión
3 personas más completaron esta guía.
Michael Wozny
Miembro Desde 02/04/16
3,693 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 17-4, Blackwell Winter 2016 Miembro de USF Tampa, Team 17-4, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G4
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 27
Todo El Tiempo: 5,283
