Saltar al contenido principal
Samsung Galaxy Tab A 9.7 Speakers Replacement
Qué necesitas
  1. Samsung Galaxy Tab A 9.7 Speakers Replacement, Back Cover: paso 1, imagen 1 de 1
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7 Speakers Replacement, Speakers: paso 2, imagen 1 de 2 Samsung Galaxy Tab A 9.7 Speakers Replacement, Speakers: paso 2, imagen 2 de 2
    • Remove the two 2.8 mm Phillips #000 screws from the speakers.
  3. Samsung Galaxy Tab A 9.7 Speakers Replacement: paso 3, imagen 1 de 1
    • Each speaker is now only connected to the main device by small plastic snaps.
    • Pry the speakers from the device at these two points using the heavy duty spudger.
Conclusión
Equipo
Cal Poly, Team S1-G3, Livingston Spring 2017 Miembro de Cal Poly, Team S1-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S1G3
1 Miembro
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 1,459
