Saltar al contenido principal
Samsung Galaxy Tab A 9.7 Rear Camera Replacement
Qué necesitas
  1. Samsung Galaxy Tab A 9.7 Rear Camera Replacement, Rear Camera: paso 1, imagen 1 de 1
    • Pry along the edge of the Samsung Galaxy Tab A 9.7 with an iFixit opening tool.
  2. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: paso 2, imagen 1 de 1
    • Insert a second iFixit opening tool along the edge and begin to pry open the back cover a little with each one.
  3. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: paso 3, imagen 1 de 1
    • Remove one of the iFixit opening tools and begin to go around the device with the other one until the back cover pops off.
  4. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Tab A 9.7 Rear Camera Replacement: paso 4, imagen 2 de 2
    • Remove five 2.8 mm screws using the Phillips #000 screwdriver.
  5. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Tab A 9.7 Rear Camera Replacement: paso 5, imagen 2 de 2
    • Disconnect all wires and strips that connect the motherboard to any other part of the device with an iFixit opening tool.
    • Lift up gently on all wires and strips.
  6. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: paso 6, imagen 1 de 1
    • Lift the motherboard out of the back panel using an iFixit opening tool.
    • Be gentle when wiggling the motherboard out from underneath the battery's protective edge.
  7. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: paso 7, imagen 1 de 1
    • Pull off the rear camera on the back of the motherboard and replace.
Conclusión
Makenzie D'Elia
Miembro Desde 04/09/19
313 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G3, Hovde Spring 2019 Miembro de IUPUI, Team S1-G3, Hovde Spring 2019
IUPUI-HOVDE-S19S1G3
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 262
