Introducción
If your device display is unresponsive or cracked, it may cause further damage to the device or physical injury. This guide will outline how to properly remove the display of the Samsung Galaxy Tab A 9.7 without damaging other parts of the device. The difficulty of this guide is moderate and requires special attention to details. Take caution when removing the display in order to inhibit the possibility of cracking the screen.
You will want to work on a clean and flat table where you will easily be able to locate all parts and tools.
Qué necesitas
Insert a metal spudger between the back case and the screen of the device.
Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
Gently remove the tape covering the screen ribbon cable, located at the top of the devise.
With the plastic spudger, disconnect the ribbon cable from the motherboard, located at the middle of the device.
3 personas más completaron esta guía.
