Saltar al contenido principal
Samsung Galaxy Tab A 7.0" Headphone Jack Replacement
Qué necesitas
  1. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement, Headphone Jack: paso 1, imagen 1 de 1
    • Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
    • Slide tool around the tablet to unlock the panels from one another.
  2. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: paso 2, imagen 2 de 2
    • Carefully remove the back panel from the front panel.
    • The inner components of the tablet will now be exposed.
  3. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: paso 3, imagen 1 de 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: paso 3, imagen 2 de 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: paso 3, imagen 3 de 3
    • Remove the two Phillips head screws attaching the auxiliary port to the plastic frame using a P000 screwdriver.
    • Remove the four Phillips head screws attaching the motherboard to the plastic case using a P000 screwdriver.
  4. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers disconnect the headphone jack connector from the motherboard.
  5. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: paso 5, imagen 1 de 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: paso 5, imagen 2 de 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: paso 5, imagen 3 de 3
    • Using tweezers, carefully lift up the motherboard.
    • Using tweezers, remove the metal jacket holding the headphone jack in place by grabbing the left corner where there is a recess to grab it.
    • There is a light adhesive holding the metal jacket down. You may have to pull slightly harder to get this off.
  6. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: paso 6, imagen 1 de 1
    • Remove the auxiliary port from the case.
Conclusión
5 personas más completaron esta guía.
Bradley Watson
Miembro Desde 02/15/17
1,079 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 5-4, Passmore Spring 2017 Miembro de USF Tampa, Team 5-4, Passmore Spring 2017
USFT-PASSMORE-S17S5G4
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 59
Todo El Tiempo: 3,997
