Introducción
If you have a damaged, broken, or corrupted motherboard, this guide will help you replace it.
Qué necesitas
Have the front of the device facing you.
Begin near one of the curved edges of the device (see photo two for visual example).
Place a plastic opening tool between the front and back panels.
Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
Slide the orange battery ribbon cable out of the ZIF connector.
Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
Flip up the two ZIF connectors on the motherboard using the plastic opening tool.
Slide the orange ribbon cables out of the ZIF connectors.
Remove the front-facing camera.
12 personas más completaron esta guía.
Un comentario
habe es geschafft zum zerlegen... leider ist nur der verschluss vom LCD hops gegangen. Ohne diesen geht wohl nix. Kein Bild.
