Saltar al contenido principal
Samsung Galaxy Tab A 10.1 Back Panel Replacement
Qué necesitas
  1. Samsung Galaxy Tab A 10.1 Back Panel Replacement, Back Panel: paso 1, imagen 1 de 2 Samsung Galaxy Tab A 10.1 Back Panel Replacement, Back Panel: paso 1, imagen 2 de 2
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
  2. Samsung Galaxy Tab A 10.1 Back Panel Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab A 10.1 Back Panel Replacement: paso 2, imagen 2 de 2
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
Conclusión
9 personas más completaron esta guía.
Isabella Li
Miembro Desde 10/02/17
2,379 Reputación
7 Guías creadas
Equipo
Cal Poly, Team S15-G6, Livingston Fall 2017 Miembro de Cal Poly, Team S15-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G6
4 Miembros
26 Guías creadas
Un comentario
Why need to remove cables when only the back has to be replaced ?
nabe_03 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 22
Ultimos 30 días: 88
Todo El Tiempo: 11,997
