Saltar al contenido principal
Samsung Galaxy Tab 8.9 Speaker(s) Replacement
Qué necesitas
  1. Samsung Galaxy Tab 8.9 Speaker(s) Replacement, Insert Opening tool: paso 1, imagen 1 de 1
    • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  2. Samsung Galaxy Tab 8.9 Speaker(s) Replacement, Insert second tool: paso 2, imagen 1 de 1
    • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  3. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: paso 3, imagen 1 de 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover.
  4. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: paso 4, imagen 1 de 1
    • Using your hands, remove the back cover.
  5. Samsung Galaxy Tab 8.9 Speaker(s) Replacement, Charging Port: paso 5, imagen 1 de 1
    • Using tweezers, peel away the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Tab 8.9 Speaker(s) Replacement: paso 6, imagen 2 de 2
    • Insert a spudger under the orange tab.
    • Pry open the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: paso 7, imagen 1 de 1
    • Slide out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: paso 8, imagen 1 de 2 Samsung Galaxy Tab 8.9 Speaker(s) Replacement: paso 8, imagen 2 de 2
    • Using a Phillips #00 screwdriver, unscrew the 4 screws (3mm) that are holding the charger port and speaker support.
  9. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: paso 9, imagen 1 de 1
    • Insert opening tool to pry support from the housing.
  10. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: paso 10, imagen 1 de 2 Samsung Galaxy Tab 8.9 Speaker(s) Replacement: paso 10, imagen 2 de 2
    • Desolder the two connections to separate the speakers from the charger port.
  11. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: paso 11, imagen 1 de 1
    • Separate charging port from speaker assembly.
Conclusión
Eric Bird
Miembro Desde 05/09/17
543 Reputación
5 Guías creadas
Equipo
IUPUI, Team S4-G2, Harley Spring 2017 Miembro de IUPUI, Team S4-G2, Harley Spring 2017
IUPUI-HARLEY-S17S4G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 13
Todo El Tiempo: 147
