Saltar al contenido principal
Samsung Galaxy Tab 8.9 Motherboard Replacement
Qué necesitas
  1. Samsung Galaxy Tab 8.9 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
  2. Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 2, imagen 1 de 1
    • 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
  3. Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 3, imagen 1 de 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
  4. Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 4, imagen 1 de 1
    • Use your hands to open the back cover.
  5. Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove Green Tape: paso 5, imagen 1 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove Green Tape: paso 5, imagen 2 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove Green Tape: paso 5, imagen 3 de 3
    • Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 6, imagen 2 de 2
    • Insert a spudger under the orange tab.
    • Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 7, imagen 1 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 7, imagen 2 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 7, imagen 3 de 3
    • Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Samsung Galaxy Tab 8.9 Motherboard Replacement, Disconnect Battery from MotherBoard: paso 8, imagen 1 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Disconnect Battery from MotherBoard: paso 8, imagen 2 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Disconnect Battery from MotherBoard: paso 8, imagen 3 de 3
    • Insert the spudger under the red, black, and white cables.
    • Pry up and detach the battery from the motherboard.
  9. Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 9, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
  10. Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove the Battery: paso 10, imagen 1 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove the Battery: paso 10, imagen 2 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove the Battery: paso 10, imagen 3 de 3
    • Use a spudger to lift up and separate the battery from its housing.
  11. Samsung Galaxy Tab 8.9 Motherboard Replacement, Motherboard: paso 11, imagen 1 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Motherboard: paso 11, imagen 2 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Motherboard: paso 11, imagen 3 de 3
    • Locate the motherboard and 5 connectors on it.
    • Pry up and detach the connector from the motherboard using the flat edge of the spudger.
    • Repeat for the 4 remaining connectors.
  12. Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 12, imagen 1 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 12, imagen 2 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 12, imagen 3 de 3
    • Using the Phillips #00 screwdriver, unscrew the 3 screws (1mm) that are located near:
    • Camera
    • Power and volume buttons
    • Tilt sensor
  13. Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 13, imagen 1 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 13, imagen 2 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 13, imagen 3 de 3
    • Using the flat edge of the spudger, pry and lift up the motherboard.
  14. Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 14, imagen 1 de 2 Samsung Galaxy Tab 8.9 Motherboard Replacement: paso 14, imagen 2 de 2
    • Pull away the motherboard from the housing.
Conclusión
4 personas más completaron esta guía.
Aleezee True
Miembro Desde 09/30/14
532 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 11-4, Blackwell Fall 2014 Miembro de USF Tampa, Team 11-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 2,322
