Saltar al contenido principal
Samsung Galaxy Tab 8.9 LCD Screen Replacement
Qué necesitas
  1. Samsung Galaxy Tab 8.9 LCD Screen Replacement, Insert Opening tool: paso 1, imagen 1 de 1
    • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  2. Samsung Galaxy Tab 8.9 LCD Screen Replacement, Insert second tool: paso 2, imagen 1 de 1
    • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  3. Samsung Galaxy Tab 8.9 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover.
  4. Samsung Galaxy Tab 8.9 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Using your hands, remove the back cover.
  5. Samsung Galaxy Tab 8.9 LCD Screen Replacement, Display: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, peel away the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 LCD Screen Replacement: paso 6, imagen 1 de 1
    • Slide out the yellow flexible ribbon cable to disconnect it from the motherboard.
  7. Samsung Galaxy Tab 8.9 LCD Screen Replacement: paso 7, imagen 1 de 1
    • Remove green tape from lcd connector.
  8. Samsung Galaxy Tab 8.9 LCD Screen Replacement: paso 8, imagen 1 de 1
    • Pull lcd cable out of connector.
  9. Samsung Galaxy Tab 8.9 LCD Screen Replacement: paso 9, imagen 1 de 1
    • Slide metal tool around perimeter to release glue.
    • Be careful not to damage the yellow ribbon cable.
  10. Samsung Galaxy Tab 8.9 LCD Screen Replacement: paso 10, imagen 1 de 1
    • Pull glass cover from main frame.
  11. Samsung Galaxy Tab 8.9 LCD Screen Replacement: paso 11, imagen 1 de 1
    • Pry screen from housing.
Conclusión
2 personas más completaron esta guía.
Eric Bird
Miembro Desde 05/09/17
543 Reputación
5 Guías creadas
Equipo
IUPUI, Team S4-G2, Harley Spring 2017 Miembro de IUPUI, Team S4-G2, Harley Spring 2017
IUPUI-HARLEY-S17S4G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 15
Todo El Tiempo: 1,537
