Saltar al contenido principal
Samsung Galaxy Tab 8.9 Charging Port Replacement
Qué necesitas
  1. Samsung Galaxy Tab 8.9 Charging Port Replacement, Insert Opening tool: paso 1, imagen 1 de 1
    • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  2. Samsung Galaxy Tab 8.9 Charging Port Replacement, Insert second tool: paso 2, imagen 1 de 1
    • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  3. Samsung Galaxy Tab 8.9 Charging Port Replacement: paso 3, imagen 1 de 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover.
  4. Samsung Galaxy Tab 8.9 Charging Port Replacement: paso 4, imagen 1 de 1
    • Using your hands, remove the back cover.
  5. Samsung Galaxy Tab 8.9 Charging Port Replacement, Charging Port: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, peel away the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 Charging Port Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Tab 8.9 Charging Port Replacement: paso 6, imagen 2 de 2
    • Insert a spudger under the orange tab.
    • Pry open the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Samsung Galaxy Tab 8.9 Charging Port Replacement: paso 7, imagen 1 de 1
    • Slide out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Samsung Galaxy Tab 8.9 Charging Port Replacement: paso 8, imagen 1 de 2 Samsung Galaxy Tab 8.9 Charging Port Replacement: paso 8, imagen 2 de 2
    • Using a Phillips #00 screwdriver, unscrew the 4 screws (3mm) that are holding the charger port and speaker support.
  9. Samsung Galaxy Tab 8.9 Charging Port Replacement: paso 9, imagen 1 de 1
    • Insert opening tool to pry support from the housing.
  10. Samsung Galaxy Tab 8.9 Charging Port Replacement: paso 10, imagen 1 de 2 Samsung Galaxy Tab 8.9 Charging Port Replacement: paso 10, imagen 2 de 2
    • Desolder the two connections to separate the speakers from the charger port.
  11. Samsung Galaxy Tab 8.9 Charging Port Replacement: paso 11, imagen 1 de 1
    • Separate charging port from speaker assembly.
Conclusión
Eric Bird
Miembro Desde 05/09/17
543 Reputación
5 Guías creadas
Equipo
IUPUI, Team S4-G2, Harley Spring 2017 Miembro de IUPUI, Team S4-G2, Harley Spring 2017
IUPUI-HARLEY-S17S4G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 17
Todo El Tiempo: 680
