Introducción
As a laptop battery ages, it will gradually lose the ability to hold a charge and die more quickly. This guide will show you how to replace your battery and bring life back to your laptop.
Qué necesitas
Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
Insert the spudger under the red, black, and white cables.
Pry up and detach the battery from the motherboard.
Use a spudger to lift up and separate the battery from its housing.
4 personas más completaron esta guía.
Un comentario
Step 8 Clearer to say:
Insert the spudger under the red, black, and white cables to pry up the battery connector and detach it and the battery from the motherboard.
