Saltar al contenido principal
Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement
Qué necesitas
  1. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Opening the tablet: paso 1, imagen 1 de 3 Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Opening the tablet: paso 1, imagen 2 de 3 Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Opening the tablet: paso 1, imagen 3 de 3
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Disconnecting the camera: paso 2, imagen 1 de 1
    • Detach the ribbon cable from the flex cable.
  3. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Removing the flex cable: paso 3, imagen 1 de 1
    • Detach all ribbon cables from the flex cable, unscrew the flex cable, and remove the flex cable. This needs to be done in order to remove the camera which sits underneath the flex cable.
  4. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Removing the camera: paso 4, imagen 1 de 1
    • Replace the original camera with the new camera. It should come right out.
Conclusión
Una persona más ha completado esta guía.
Stephanie Wong
Miembro Desde 09/26/14
973 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 13-2, Staggers Fall 2014 Miembro de USF Tampa, Team 13-2, Staggers Fall 2014
USFT-STAGGERS-F14S13G2
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 681
