Introducción
Replacing the Motherboard is the most complex replacement for the tablet. It utilizes most of the steps from other guides, like battery, front facing, and rear facing camera removals.
Qué necesitas
Gently insert the plastic opening tool between the metal rim and the back plastic casing at the bottom of the tablet and pry the back casing away from the device. Continue to separate the back panel of the device from the front assembly.
The front facing camera's ribbon cable is located at the top edge of the motherboard, slightly left of center.
Slide the flat end of the blue plastic opening tool underneath the connector at the end of the ribbon cable.
The rear facing camera will be located just to the right and below the front facing camera, near the top and center of the motherboard.
Slide the opening tool underneath the connector and apply slight pressure upwards and outwards until the metal connector pops from its socket on the motherboard.
Replace the defective motherboard with the new one, then, to reassemble your device, follow the instructions in reverse order.
3 personas más completaron esta guía.
