Saltar al contenido principal
Samsung Galaxy Tab 4 8.0 Verizon Speaker Replacement
Qué necesitas
  1. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: paso 1, imagen 1 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: paso 1, imagen 2 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: paso 1, imagen 3 de 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
  2. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 2, imagen 3 de 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold rectangular connector from its socket on the mother board.
  3. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 3, imagen 1 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 3, imagen 2 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 3, imagen 3 de 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold square connector from its socket on the mother board.
  4. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 4, imagen 1 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 4, imagen 2 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 4, imagen 3 de 3
    • Using the spudger gently wedge the blue wire out of its compartment.
  5. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 5, imagen 1 de 1
    • Remove two 2 mm #000 Phillips screws securing the metallic charger port cover to both the logic board and the front panel.
  6. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 6, imagen 1 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 6, imagen 2 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Squeeze the metal charger port cover piece with the tweezers to gently lift it from it's place.
  7. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 7, imagen 1 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 7, imagen 2 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 7, imagen 3 de 3
    • Carefully insert the flat end of the blue plastic opening tool under the black plastic fastener and lift.
    • Rotate your tablet counter clockwise to facilitate the process.
  8. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 8, imagen 1 de 2 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 8, imagen 2 de 2
    • Squeeze the golden cable with the tweezers and gently pull the cable to the left to free the end of the golden cable.
    • The golden cable is delicate so use gentle force.
  9. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 9, imagen 1 de 1
    • Remove three 2 mm #000 Phillips screws securing the mother board to the front panel.
  10. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 10, imagen 1 de 2 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 10, imagen 2 de 2
    • Using your hands, hold the opposite ends of the mother board corners, and lift.
  11. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Speaker: paso 11, imagen 1 de 1
    • Insert the opening tool tip into the crack between the speaker and device.
  12. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: paso 12, imagen 1 de 1
    • Gently pry up on the speaker to disconnect the speaker from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 142
