Saltar al contenido principal
Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement
Qué necesitas
  1. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement, Rear Case: paso 1, imagen 1 de 3 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement, Rear Case: paso 1, imagen 2 de 3 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement, Rear Case: paso 1, imagen 3 de 3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: paso 2, imagen 2 de 2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: paso 3, imagen 1 de 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: paso 3, imagen 2 de 2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement, Rear Facing Camera: paso 4, imagen 1 de 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement, Rear Facing Camera: paso 4, imagen 2 de 2
    • The back camera will be located near the top of the tablet in the center above the battery.
    • Carefully insert the flat end of the blue plastic opening tool under the metal rectangular end of the back camera’s cable connector.
  5. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: paso 5, imagen 1 de 1
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the back camera’s metallic rectangular connector from its socket on the logic board.
  6. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: paso 6, imagen 2 de 2
    • Squeeze the metallic rectangular piece with the tweezers to gently lift it from it's pit.
Conclusión
2 personas más completaron esta guía.
Yuly Flores
Miembro Desde 09/14/15
747 Reputación
1 Guía escrita
Equipo
CSU Fullerton, Team 1-3, Bruce Fall 2015 Miembro de CSU Fullerton, Team 1-3, Bruce Fall 2015
CSUF-BRUCE-F15S1G3
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 916
